RESET
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: RESET
Hello Alan.
There seem to be two ways to reset an ATMEGA8 from within a program.
1. Connect an unused output to the /RESET input and control it from the program.
2. Allow the watchdog to time-out.
If the watchdog is not being used during normal program execution it can be turned on when a reset is required, and the main program can execute a loop until the reset is forced. This will take a minimum of 15ms.
The following C code should enable the watchdog function. Note: the watchdog enable fuse should be left un-programmed in this case (default condition) to prevent the watchdog from being enabled permanently.
wdt_enable(WDT0_15MS);
If the watchdog is being used, the reset can be forced by failing to execute the wdt_reset() instruction within the time-out period.
If you want to look at the WinAVR watchdog commands they are defined in the wdt.h file in the Tools\avr\include\avr\ folder of the Flowcode installation.
Sean
Re: RESET
One additional requirement for the reset functions to work; the wdt.h file must be included in the compilation.
Add the following code to the 'Definitions and function declarations' panel in the 'Edit->Supplementary Code...' menu:
#include <avr\wdt.h>
Re: RESET
hello sean
there seem to be some kind of problem it's not compiling to hex
ile name: C:\Documents and Settings\ALAN\Desktop\test\test.c
Generated by: Flowcode v3.3.4.44
Date: Thursday, January 24, 2008 19:10:35
Licence: Professional
Registered to: Alan Cilia
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode_AVR\Tools\MX_bats\avra.bat atmega8 "C:\DOCUME~1\ALAN\Desktop\test\test.elf" "C:\DOCUME~1\ALAN\Desktop\test\test.c" "C:\DOCUME~1\ALAN\Desktop\test\test.lst"
C:\Documents and Settings\ALAN\Desktop\test>"C:\PROGRA~1\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\bin\avr-gcc.exe" -mmcu=atmega8 -Os -funsigned-char -o "C:\DOCUME~1\ALAN\Desktop\test\test.elf" "C:\DOCUME~1\ALAN\Desktop\test\test.c"
C:\DOCUME~1\ALAN\Desktop\test\test.c: In function 'main':
C:\DOCUME~1\ALAN\Desktop\test\test.c:104: error: 'WDT0_15MS' undeclared (first use in this function)
C:\DOCUME~1\ALAN\Desktop\test\test.c:104: error: (Each undeclared identifier is reported only once
C:\DOCUME~1\ALAN\Desktop\test\test.c:104: error: for each function it appears in.)
Error returned from [avr-gcc.exe]
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
Return code = 1
FINISHED
Sean
Re: RESET
A correction to the spelling of the watchdog timer definition names.
The prefixes contain the letter 'O', not the number '0'.
The command to set the minimum watchdog timer period should be:
wdt_enable(WDTO_15MS);
not
If #include <avr/wdt.h> has been added to the supplementary code this definition will be available to the program.
not
