I2C 20x4 LCD with HD44780 - Proteus
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hi, using HD44780 I2C LCD 4 x 20.
When I try to run the .hex in Proteus V4.8.7 using LM044l display it doesnt works.
What can I do?
Diagram with Arduino mega 2560 R3
Has here attached:
Flow Code V6:
I2c DispTest.fcfx
(6.18 KiB) Downloaded 1189 times
Hex file:
I2c DispTest.hex
(11.34 KiB) Downloaded 1053 times
Best Regard
Monie
Last edited by Monie Jacobsen on Tue Jun 28, 2016 7:43 am, edited 2 times in total.
Best Regard
Monie
Monie Jacobsen
Re: I2C 20x4 LCD with HD44780 - Proteus
continued:
Proteus V4.8.7 File: Can not attached Proteus file!
Best Regard
Monie
Monie Jacobsen
Monie Jacobsen wrote:continued:
Best Regard
Monie
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
hi monie
append at end of file name simple with .zip
example:
orig file: test.zzz
append: test.zzz.zip
then you can upload the file
and give the info, that is only append and not compressed
hope this helps
best wishes
rudi ;-)
Monie Jacobsen
Thank You Rudy
Ok with upload via zip
Last edited by Monie Jacobsen on Tue Jun 28, 2016 11:43 am, edited 1 time in total.
Best Regard
Monie
Monie Jacobsen
Here is attached Proteus file:
Eletronik.zip
(23.83 KiB) Downloaded 1243 times
Best Regard
Monie
Dan81
Been thanked: 60 times
Post by Dan81 »
Hello Monie
I've made a test with my own schematic (Proteus 8.2) .
The flowvchart works fine if I choose "I2C hardware" (channel1) .
I don't see your pull up resistors (SCL ,SDA) .
Daniel
(312.91 KiB) Downloaded 1052 times
Monie Jacobsen
Hello Dan81
Thanks for your reply.
But do not be able to get I2C to operate so it can be anything in the display.
Tried to correct but can not get I2C for Display to work!
Hope you will be helpful for a solution to the problem
Has attached the edited diagram:
And attached coderne to Proteus:
I2C_LCD_Display-003.zip
(20.61 KiB) Downloaded 1260 times
From my Proteus Library Mega 2560:
Arduino-Library-for-Proteus.rar
(17.3 KiB) Downloaded 897 times
Bedst Regard
Last edited by Monie Jacobsen on Tue Jun 28, 2016 8:00 pm, edited 1 time in total.
Best Regard
Monie
Dan81
Post by Dan81 »
Hello Monie
I can't open your file (Proteus v8.5) .
here my project (v8.2).
Daniel
test_lcdi2c.zip
(16.99 KiB) Downloaded 840 times
Monie Jacobsen
Hello Dan 81
Thank you very much.
Trying to work with your coder;-)
Best Regard
Monie
