External Interupts dont work
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
MTTweaker
Has thanked: 3 times
Post by MTTweaker »
I made a flowchart with external interrupt using RB0 on PIC16F1937 in the e block, and when i press the switch the interrupt don't work, like it don't exist. i have attached the code.
when i use this with FC6 it works fine.
Flowcode1.hex
compiled file of the attached flowchart
(8.62 KiB) Downloaded 345 times
Flowcode1.fcfx
LCD connected on port D of PIC16F1937, INTpin RB0, its a second counter, and when you press SW on INTpin it resets the counter to 0
(11.49 KiB) Downloaded 350 times
PaulNe
Has thanked: 2 times
Been thanked: 23 times
Re: External Interupts dont work
Post by PaulNe »
Hi MTTweaker,
Thanks for reporting the bug. It's logged in the system, and should be fixed for the next patch.
Paul
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi MTTweaker!
A slightly modified the flowchart.
Please try this version in FC7.
I am interested in your opinion.
Lagoda
Flowcode1_2.fcfx
(12.08 KiB) Downloaded 366 times
MTTweaker
Post by MTTweaker »
the blinking LED part works, but the interrupt that is going to reset the counter doesn't do anything.
its like the interrupt pin don't exist
Lagoda
Post by Lagoda »
Unfortunately, I could only test in the simulator, but this version worked.
Did you test in your target board or simulator?
MTTweaker
Post by MTTweaker »
I tested in the target board..
Hi MTTweaker,
It looks like GIE is not being enabled.
Attached is an unofficial temp fix.
Just place the attached file in:
C:\Program Files (x86)\Flowcode 7\FCD\PIC
or
C:\Program Files\Flowcode 7\FCD\PIC
Depending on which windows version you have.
16F1937.fcdx
(25.61 KiB) Downloaded 349 times
