Unable to program using Mloader
Zane
Flowcode v5 User
Has thanked: 93 times
Been thanked: 76 times
Post by Zane »
Using Mloader and trying to program a PIC18F26K80 i get the following message
Using a PIC16F88 and it works ok.
Has thanked: 114 times
Been thanked: 422 times
Re: Unable to program using Mloader
Post by Steve »
mLoader does not support the k80 at the moment and I cannot test it here because I do not have any of those chips, but I have tried to guess the fix...
If you use the attached files instead of the ones in the mLoader directory then it might work, but I cannot guarantee it.
If you do try, please make a copy of the original files and also let me know how you get on. If it works, we will add the files to the next update of Flowcode.
8bConfigData.csv
(101.59 KiB) Downloaded 267 times
ppp_chip_script.cfg
(32.11 KiB) Downloaded 270 times
Zane
Flowcode v5 User
Post by Zane »
Hi Steve,
I have transferred over the files and tried programming the chip but get this message now.
There is no rush for this , its something i found and thought i would let you know.
