Digits to ULong number conversion problem
sysprofessional
Has thanked: 28 times
Been thanked: 4 times
Post by sysprofessional »
I want a value from 5 separate digits,that are feed bye user on 7 segment display.I am using this method
Total = (digit[0] * 10000) + (digit[1] * 1000) + (digit[2] * 100) + (digit[3] * 10) + digit[4]
Total is a ULong (number in the range 0 to 4294967295) 32 bit variable .
This method works fine in Flowcode ,but when i move on proteus Total variabale work like UInt 16 bit variable.when value reached to 65536 Totale variable overflow and start from 0.
I am using 18f14k22 with internal 16MHz oscilator in my application .i have confused,please suggest me wright way.
Best Regards
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Digits to ULong number conversion problem
Post by kersing »
Post your flowchart so we can check it for issues.
― C.S. Lewis
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
On your target, any intermediate/temporary calculations will be 16 bit, so you will need to ensure that any sub-totals are Ulongs too
sysprofessional
kersing wrote:Post your flowchart so we can check it for issues.
Hello kersing,
Basically i am using 11 digit in my application using dual MAX7219 and many other features so my flowchart is little lengthy. Here i have design new flowchart for your observation .That is small and easy to understand.
My flowchart, hex, cof, and proteus simulation files attached below in compressed rar format.
Best Regards:
Flowchart+Simulation.rar
(43.35 KiB) Downloaded 393 times
sysprofessional
LeighM wrote:On your target, any intermediate/temporary calculations will be 16 bit, so you will need to ensure that any sub-totals are Ulongs too
I have already ensured that there is no temp or any other variable between calculation,i am using only one 32 bit variable ,and all calculations moves directly into that variable.i have also attached flowchart now ,please see that ,
LeighM
Post by LeighM »
sorry, I did not explain that too well
The compiler will produce code to calculate "(digit[0] * 10000)" using a temporary variable, which will only be 16 bits on this target processor, hence the 65536 limit.
So you will need to create a Ulong SubTotal variable to force this calculation into 32 bits
SubTotal = 10000
SubTotal = SubTotal * digit[0]
Total = SubTotal + (digit[1] * 1000) + (digit[2] * 100) + (digit[3] * 10) + digit[4]
Hope that helps,
Leigh
sysprofessional
Thank you very much LeighM ,
I have well understand now,This method working fine in my application.Good luck to you.
