NRF24L01!
jgu1
Has thanked: 1135 times
Been thanked: 299 times
NRF24L01!
Post by jgu1 »
Hi !
I can see that in FC7 included component NRF23L01 :D . I really like to use it, but I have no experience with this and don´t know how to start.
Before I started to experiment with this and spend hours on it, I'll hear about the MM has tested the component. :wink:
And please a litlle starthelp,
What is Pipeadress? Openwriteadress, Openreadingadress and setPipeAdress and how to use. Has it something to do with identification, node?
I know MM guys is busy, but how long is the schedule for the help function for FC7? And will there be, as in FC6 get some good examples of the different components. A simple example of just sending and receiving a number would be fine.
Thank´s in advance
Best regard
Jorgen
Re: NRF24L01!
Hi Jorgen,
I'll see if I can get some examples created for you.
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi Ben!
Thank you. I Will be really gratefull. Only a simple examble, maybe to Remote control an output, on/OFF. :D
Best regard
Jorgen
Re: NRF24L01!
Hi Jorgen,
I really didn't like the current state of the component. The code came from an Arduino library and it just felt a bit too unwieldy and complicated.
So I've re-written the component to heavily simplify it based on the working example posted here by MJU.
http://www.flowcode.co.uk/mmforums/viewt ... l01#p71942
The latest component file is here, simply copy the file to your "Flowcode 7/Components" directory and restart Flowcode.
nRF24L01.fcpx
(11.45 KiB) Downloaded 680 times
Here are some example programs to show you how to send and receive data.
NRF24L01_RX_Example1.fcfx
(8.32 KiB) Downloaded 738 times
NRF24L01_TX_Example1.fcfx
(8.69 KiB) Downloaded 753 times
A new updated wiki page has been created for the new component here.
http://www.flowcode.co.uk/wikiv7/index.p ... (Wireless)
Let me know how you get on.
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi Ben!
Thank you thank you, very much for your big job. :D :D I am not home before the weekend, but as soon I am home I make a test with your component and program and you hear from me.
Great :lol:
Jorgen
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi Ben!
Unfortunately it is not working. :(
Let me tell you what I have done.
RX:
First I overwrite the fcdx file in the component lib. Then I programmed the chip and I can see that is running, while in the display I see "Init OK". For the rx module I have exactly 3,3 Volt for supply, and I have added a 10uF capacitor on the supply for the module. ( can see in different forum they recommend this) Check and check the wiring again. The only thing I not have connected is IRQ.
TX:
The same have I done on the TX. I also suppose that the program is running there, because when I press a digit on the keypad A0 go high. I can see with my scoope a short puls is coming out on the different data pin when I press a digit on the keypad.
The NRF module is new and the distance between them is max 1 Meter.
Sorry!
Br. Jorgen
Re: NRF24L01!
Right I'll get my fine comb out and see if I can spot any problems in the code. I also have some of these modules at home so if I get time I will double check things at my end. I have one module sat in front of me on my desk, however one is not enough to do anything meaningful other than check the initialise comms are ok.
jgu1
Re: NRF24L01!
Post by jgu1 »
Thanks Ben!
Br
Jorgen
Re: NRF24L01!
Right I've made a test rig and been through the code carefully now.
I have found two problems with the current component code.
1) There was no SPI prescaler property so no way to control the SPI speed. This has now been added.
2) The CE pin was being driven high at the end of the RX init in MJU's example and I had missed this. This has now also been added.
Even with the two improvements listed above it's still not working for me? Hmmm.
Latest component file.
nRF24L01.fcpx
(11.61 KiB) Downloaded 537 times
Re: NRF24L01!
Scratch that, it's working now.
Had missed another pin change in the initialise.
nRF24L01.fcpx
(11.6 KiB) Downloaded 569 times
Here are the working examples, note that the FIFO size is 32 bytes, I think this is important so I'm going to try and make this more flexible now.
(8.51 KiB) Downloaded 597 times
(8.69 KiB) Downloaded 563 times
Edit: Yes confirmed buffer sizes other than 32 bytes don't work. I'll see if I can find a way to edit this but for now it works well if you always send and receive 32 bytes at once.
electron67
Has thanked: 106 times
Been thanked: 48 times
Re: NRF24L01!
Post by electron67 »
Hi Benj
this component is possible to apply to flowcode 6 ?
Enrique
Re: NRF24L01!
Hello Enrique,
Sorry this is a new component for Flowcode v7 and so not available in Flowcode v6.
We still support Flowcode 6 but we won't be generating any new content for it.
The v7 component is based on the v6 example by MJU.
http://www.flowcode.co.uk/mmforums/viewt ... 78&p=71942
electron67
Re: NRF24L01!
Ok thanks Benj
I hope soon to buy flowcode 7
Enrique
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: NRF24L01!
Post by JohnCrow »
On your FC component properties you have Port D.1 connected to SCK and on the bottom line its called CLK Remap. Why the 2 different names?
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi Ben!
I have first seen your corrections now. I Will run a test tomorrow evening. I dont know if Johns observations have Any influence on the program.
Thank's in advance to both of you.
Yes Enrique, buy FC7. Many good benefits, and among this, fast compiling. :D
Br. Jorgen
Re: NRF24L01!
Hi John,
The three hardware SPI pins MOSI, MISO and SCK are greyed out and set by the internal wiring of the microcontroller.
On the microcontroller I am using the SPI is "Remappable" meaning you can shift the pins around which then creates the second set of properties.
The First greyed out SCK pin is our usual this is where the SCK is connected to indicator.
The second none greyed out SCK pin assigns where we are mapping the SCK pin and should be reflected by the first greyed out property.
Ideally there shouldn't be two properties but I didn't just want to hide the standard SCK property in case that confused anyone.
JohnCrow
Re: NRF24L01!
Post by JohnCrow »
The boards should be here tomorrow.
I've ordered a pair of Sparkfun BOB's with a SMA connector and built in voltage regulator so they can be run from the 5v supply and a pair of 2.4GHz rubber duck aerials to match.
At least I will know they are going to work. (unlike a Chinese special that may have problems :roll: )
Hopefully I will get a decent signal between them too with these aerials. (2.2dBi Gain)
Will post my results once tested.
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi Ben and john!
In contrast to the first exemplary Tx and Rx was all set. Both in chip and component macro.
Now I can´t find in component macro TXmode and RX, where I have to place the
adress :
0x11
0x11
0x11
0x11
I thing I wait until I can test with John´s examble, if ok. I have not experience with these device. Thank´s John.
Best regard
Jorgen
JohnCrow
Re: NRF24L01!
Post by JohnCrow »
Hi Jorgen
I've not used these yet myself will be starting with Bens sample flowcharts and go from there.
Should be interesting project.
Re: NRF24L01!
Now I can´t find in component macro TXmode and RX, where I have to place the adress :
0x11
0x11
0x11
0x11
The address is set in the examples as part of the SetTxMode or SetRxMode macros.
JohnCrow
Re: NRF24L01!
Post by JohnCrow »
My new NRF2401 boards & aerials have arrived.
Tested using Bens component and FC programs, Though tweaked to use a pair of EB006V9s and PIC16F1937's as I don't have a EB091.
Pleased to report it works fine sat on the bench. Now to see what sort of distance it will connect over.
Before Soldering Headers
Rubber Duck.JPG (56.8 KiB) Viewed 22219 times
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi John!
Glad it work´s for you. Do you want to share your (Ben´s) testprogram. Then I know for sure that these file you have testet work´s and all config is ok?
Yes mine is from Ebay, maybe I should buy some like yours.
Thank´s in advance
Jorgen
JohnCrow
Re: NRF24L01!
Post by JohnCrow »
Hi Jorgen
You are welcome to the test programs.
They are basically the same as Bens, except they are for a 16F1937
Ben's programs are further up the page.
Pin Outs
EB006 - RF Board
C2 - CE
C3 - SCK
C4 - MISO
C5 - MOSI
C7 - CSN
NRF24L01_RX_Example1_PIC.fcfx
(8.57 KiB) Downloaded 541 times
NRF24L01_TX_Example1_PIC.fcfx
(8.75 KiB) Downloaded 486 times
The boards were about £15.00 each and the rubber duck aerials about £4.00
Plus having a 5V regulator on board they can run directly of the EB 006 without any extra components.
electron67
Re: NRF24L01!
HI Jorgen, John and Benj
You know the maximum distance range of NRF24L01 using it on the street :?:
I'm using ZigBee mentioned a range of 1 km but in the city is 80 meters and the cost is 40 dlls each; and the nrf24l01 have to cost of 3 to 5 dlls each. . .
Enrique
jgu1
Re: NRF24L01!
Post by jgu1 »
Hi all!
Thank's John for sharing. I'll test it later today.
And Enrique, yes I know all these small devises, but no have no experience with these, but like to learn about it, i Think they are a little tricky. :wink:
Br
Jorgen
