KeyPad 4X4 Error
seokgi
- Has thanked: 18 times
- Been thanked: 16 times
KeyPad 4X4 Error
Using keypad 4x4.
But Column 1, 2 signal is out. 3, 4 signal is nothing.
Sorry! english little.
I have Ghost & FC7 PIC.
- Flowcode2.fcfx
- (13.73 KiB) Downloaded 324 times
Re: KeyPad 4X4 Error
Please could you attach your program that is demonstrating the bug.
Right your using pins A6 and A7 for those bits on the keypad.
In the device configuration settings (Build -> Project Options -> Configure Tab) your Oscillator is set to HS crystal oscillator which also uses pins A6 and A7.
If you need to use A6 and A7 then you will need to switch the oscillator type to INTOSC.
The INTOSC helper component available from the Tools -> Matrix Tools component menu will help you to configure the internal oscillator.
http://www.flowcode.co.uk/wikiv7/index.p ... 38a5735b6e
If your using an EB006 then there is a jumper (J18/J19) which configures if A6 and A7 are connected to the on-board crystal (OSC) or the PortA I/O D-Type connector (A6&7).
seokgi
How about this Program. Use port B
- Flowcode2.fcfx
- (12.74 KiB) Downloaded 315 times
The second program looks like it should work fine.
Are you saying that pins B6 and B7 are also not doing anything?
Hmm,
The C code all looks ok to me, specifically the "MX_UINT8 FCD_08c31_keypad_base1__GetIndex()" macro which is responsible for scanning the keypad.
I'm going to compile and put the code on a micro and double check that all the column pins are firing.
Your not using ICD are you, the default ICD pins on the 16F1937 are B6 and B7? Also are you programming via a PICkit or other programmer that could be interfering, B6 and B7 are the chips programming pins.
while (FCL_INDEX < 4)
switch (FCL_INDEX)
case 0:
#if (1) // 4 >= 1
FCP_SET(B, B, 0x10, 0x4, 1);
// #else
//Code has been optimised out by the pre-processor
#endif
break;
case 1:
#if (1) // 4 >= 2
FCP_SET(B, B, 0x20, 0x5, 1);
// #else
#endif
break;
case 2:
#if (1) // 4 >= 3
FCP_SET(B, B, 0x40, 0x6, 1);
// #else
#endif
break;
case 3:
#if (1) // 4 >= 4
FCP_SET(B, B, 0x80, 0x7, 1);
// #else
#endif
break;
default:
}Your not using ICD are you, the default ICD pins on the 16F1937 are B6 and B7? Also are you programming via a PICkit or other programmer that could be interfering, B6 and B7 are the chips programming pins.
Right the program wasn't running correctly for me because the PLL enable bit was set in the chips configuration.
I'm using a 19.6608MHz crystal on my hardware so the 4X PLL was multiplying the frequency too high to operate the device correctly.
Once I made this change I am getting spikes on all four column pins.
Here is the current project with the PLL disabled.
