saving the programmer settings
litvinovee
Tell me please. Error saving the programmer settings . while trying to save data changes . but should get out of the setting ( close ) and default . windows reinstalled .
Re: saving the programmer settings
Not to sure what your referring to?
Do you mean: Can you explain in more detail please.
litvinovee
there is no way to change nastroykivverhu. only the lower setting after installation jackdaws. but they are not retained when you modify and save.drawing as an attachment.medelec35 wrote:Not to sure what your referring to?
- 00.jpg (77.4 KiB) Viewed 3491 times
For Arduino Targets the correct programmer options are automatically entered for you from the Device definition file (FCDX).
See the Project options to specify your Arduino COM port.
If you need to change the settings then do you have the right Arduino target device selected?
If you're sure you need to change the settings then please see this topic on how to do it.
viewtopic.php?f=7&t=18157#p77325
Let us know how you get on.
