After making the last update I can't compile my project to hex , I am having these Errors
See Attachment .
AVR_CAL_PWM.c
Re: AVR_CAL_PWM.c
Changing cal_pwm.fcpx with the old in the component folder will fix the problem .
But don't know why .
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Re: AVR_CAL_PWM.c
It might be the same problem as PIC side of PWM macro had with declaring some things inside the PWM file:
http://www.flowcode.co.uk/mmforums/viewt ... 64&t=18084
Re: AVR_CAL_PWM.c
Hi EtsDriver
Just tried to replace the file from that POST but it seems to be the same File in the
Last update so it dose not fix the problem .
Re: AVR_CAL_PWM.c
Hi Alan,
Please can you post the project that is generating these compilation errors and I will investigate.
Re: AVR_CAL_PWM.c
This should fix the problem.
The file needs to be placed into the "Flowcode 7/CAL/AVR" directory.
Re: AVR_CAL_PWM.c
Hi Benj
Yes i Can confirm that the file AVR_CAL_IO.h Fixes the problem
Alan
Alan
