SSD1305 Component Macro problem?
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Re: SSD1305 Component Macro problem?
Post by Lagoda »
Hello Ben,
Unfortunately, the situation has not changed. I see the same as the previous photo.
On the left side of the image pixels are lit scattered in 4 column.
In the four column the "Clear Display" function is not working.
And it would be nice if the 0,0 point is to appear in the upper left corner.
Thanks,
Lagoda
Hi Lagoda,
Have you changed the value of the H Offset property? I thought a value of 4 would fix the issue, the default is 0. Have you tried any other values?
Lagoda
Post by Lagoda »
I checked, surely I changed to the new file.
And I set the following:
X=4 Y=0 "Thanks for helping"
X=4 Y=32"Volume=1000"
Now it looks like
Hi Lagonda,
Please can you attach your current Flowcode program just so I can be sure we are on the same page.
Lagoda
Post by Lagoda »
I attached it.
1305display_test011.fcfx
(8.74 KiB) Downloaded 338 times
Hi Lagoda,
Thanks for the file. Please can you try this and let me know how you get on. I'm hoping that coordinate 0,0 should be 0,0 on the display now using the H Offset property with the value 4.
1305display_test012.fcfx
(8.75 KiB) Downloaded 381 times
Lagoda
Post by Lagoda »
Here is the result :)
Brilliant, looks like we're finally there. :mrgreen:
I've rolled out the changes to the none buffered SSD1305 component now too if anyone else needs this.
Let me know if anything else crops up.
Lagoda
Post by Lagoda »
Hello Ben,
Thank you very much for your help. :D :D
I am very pleased because I can handling the display.
I hope this will be the last question from this component.
How can I to rotate the display content?
If I using the "Display Orientation" function with parameter "2" I get the next screen:
Do you have any idea?
Best Regards,
Lagoda
1305display_test013.fcfx
(8.96 KiB) Downloaded 352 times
The lit pixels directly underneath the text is interesting. All the display orientation macro should do is fiddle the coordinates.
0, 0 becomes 127,63
1, 1 becomes 126, 62
It looks like this display your using is really messed up in terms of it's addressing. I'll take another look at the code but I can't really see a nice way of solving this at the moment.
Maybe you could do a bit more testing. e.g. light up specific pixels and see if you can map which pixels are working and which aren't.
Lagoda
Post by Lagoda »
I tried a few settings.
Is this help for you?
1305display_test015.fcfx
(11.03 KiB) Downloaded 349 times
(167 KiB) Downloaded 1504 times
(251.35 KiB) Downloaded 1504 times
Right please can you try this out and hopefully the problem will now be resolved.
gLCD_SSD1305_buffered.fcpx
(7.56 KiB) Downloaded 272 times
Printing "OOOOOO" at 94, 0 is ok.
Printing "123123123" at 0, 59 is not ok. The coordinates should be 0, 54 to correctly fit the vertical 8 bits onto the screen at pixels 54-63.
0, 55 will also probably work ok as the text is generally only 7 pixels high.
Lagoda
Post by Lagoda »
Hello Ben,
It's magic! :o
Each pixel lit in their own position and what I programmed The Component Macro does it.
Super. :D :D :D
I think this bug is cured by you.
Best Regards,
Lagoda
Phew, that is good news :D
Glad I could be of help. Turns out a lot of the display components had the same problem so I have been through and fixed it in all of them now.
Thanks for your patience and help to get this up and running.
Lagoda
Post by Lagoda »
:D
