Enqury about The product & an Error
A forum where Flowcode v7 user created components can be shared, discussed and reviewed.
mdism
Post by mdism »
Hello...
I am a new user of flowcode V7.
I am using the evaluation version. we like this product and we are planing to Buy it.
before that i have some doubts.
1) i have seen http://www.flowcode.co.uk/flowcode/buy/purchase.php
i want to know what will be the difference between Student version and professional
if only a single using will be going use this.
2) what will the burner ones i purchase and make a program, how to burn the program into uC. is there and special hardware provided or it can be done using my old PICkit3, ICD3, if there is special hardware provided what will be the cost.
3) i am using trial version can i use it to program my uC.
4) what ever components i will buy as per the above URL, is there any extra cost or this is one time payment. if not what will be scheme.
5) i am getting an Error
when ever i save or compile the flowcode.
6) can i use the hex file and load using PICKit3 from outside?
Please explain
Thank you
Mohammed Ismail
keets India
+918689904688
md.ismaaill@gmail.com
Error Showing
(105.2 KiB) Downloaded 1090 times
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Enqury about The product & an Error
Post by DavidA »
I will try answer your questions.
1) Difference between the Standard version and Professional version is simply that the Professional version gives you commercial rights to sell products using Flowcode code. Standard version does not.
2) You can use your own hardware, PICKit3 will directly interface with Flowcode, please see this wiki entry for more info on this:
http://www.flowcode.co.uk/wikiv7/index.p ... ming_Tools
3) Using the 30Day trial you should be able to program to a microcontroller
4) Buying packs is a one off purchase, there is no rolling cost or subscription.
5) Hmm, does this error still occur if you close the "Start Page" tab?
6) Yes you can load the hex file into any programmer software you like.
mdism
Post by mdism »
Thanks for the reply.
Yes, it keeps coming even after closing the start tab.
1) One more thing i want to ask is what if i want to debug the code online i mean like mplab debug directly on my controller board and flowcode.
is there any additional hardware required. or i can use my PicKit or ICD
mdism
Post by mdism »
one more thing
if i buy Professional version can i use in 2 different PCs
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
Hi mdism
Any flowcode licence allows you to load the software on your main PC and another pc owned by you, say your laptop, but a single licence only allows you to run one copy at a time.
If you want to run more than one copy at once you will need two or more licences.
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
mdism wrote:One more thing i want to ask is what if i want to debug the code online i mean like mplab debug directly on my controller board and flowcode.
Our FlowKit V2 product allows programs to be debugged while running on the hardware (our "Ghost" technology). There are two "flavours" of this product:
  1. Standalone - usable on any target:
    http://www.flowcode.co.uk/webshop/flowkit-v2.html
  2. Arduino shield - usable on any target which used this footprint:
    http://www.flowcode.co.uk/webshop/flowki ... hield.html
If you are using E-Blocks as your hardware development platform, "Ghost" is already on the EB006 and EB091 upstream boards.
