DS18B20
dedajozo
Has thanked: 8 times
Been thanked: 6 times
DS18B20
Post by dedajozo »
I'm triing to make DS18B20 termometer, chip si running with 10mhz external crystal, 4,7k resistor is connected but program is not working. Only it writes sometimes 7.5 or 0.
In the attachment is program. I tried to make termometer with LM35 an everything works fine..
Thank you in advance
TermometarDS18B20.fcfx
(7.02 KiB) Downloaded 416 times
Re: DS18B20
Is this any better? I removed one of your calculation icons which I don't think was required.
(8.2 KiB) Downloaded 467 times
dedajozo
Re: DS18B20
Post by dedajozo »
Hello Benj,
now I have value 127,5, and nothing hapends.
Re: DS18B20
Your microcontroller speed may also be a bit low, 10MHz on a PIC is probably too slow to reliably do 1-wire comms. Can you run the PIC at 20MHz instead? This should then hopefully work correctly.
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Re: DS18B20
Post by jgu1 »
Hi!
I managed to get Ben´s example to work with a Pic16f877A and a 19.xx MHz Xtal signal. In on D1. I also use some calculation from an old DS18B20 project from Flowcode 5.
You remember pullup resistor :?: :lol:
It work nice by me. Maybe this work by you. Good luck.
But Ben, if you see this? If I import this program in FC7 it does not work.??
Br
Jorgen
TermometarDS18B20Test.fcfx
(6.82 KiB) Downloaded 413 times
celebriums
Has thanked: 71 times
Been thanked: 33 times
Re: DS18B20
Post by celebriums »
Hi Jgi
Will you try the attached file? My circuit in my running smoothly.
TermometarDS18B20_SAD.fcfx
(10.56 KiB) Downloaded 406 times
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
jgu1
Re: DS18B20
Post by jgu1 »
Hi again!
Do you test mine??
Your new program work fine by me also. I dare to change a little on your program. :D
Br
Jorgen
TermometarDS18B20_SAD1.fcfx
(9.12 KiB) Downloaded 452 times
dedajozo
Re: DS18B20
Post by dedajozo »
Thank you all I will try it.
dedajozo
Re: DS18B20
Post by dedajozo »
I tried all versions with 20 mhz crystal but it is not working.
