Dear,
I am starting to work with flowcode 7. I am doing a test with the PIC18F4520 but gives me the following error when compiling.
Employing 18F4520 errata work-arounds:
* Corrupted fast interrupt shadow registers
Prueba.c:
36: __config("__PROG_CONFIG", "pic18", 0x4, 0xFFFF);
^ (1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe notificado código de error 1""
Pic18F4520
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Pic18F4520
Try to disable extended CPU set under the Configurations tab for the chip!
It worked for me just know
- 1.JPG (62.95 KiB) Viewed 3914 times
- 2.JPG (38.62 KiB) Viewed 3914 times
Regards QMESAR
Regards QMESAR
