I have a problem with "arduino micro pro card".
If I create the my program with "arduino micro selected , my card not programmed; for program it, I need select "arduino leonardo card" why?
thanks
arduino pro micro programming
Re: arduino pro micro programming
The Arduino Micro definition file uses this command line.
The Arduino Leonardo uses this command line.
They should be exactly the same. Can you check on the compiler output window what is actually being send with the two targets selected.
Also check the COM port in the project options window is specified correctly.
<programmer exe="$(appdir)compilers\avr\batchfiles\avrc_arduinoA.bat" params="atmega32u4 avr109 com7 57600 "$(target).hex"" UsesComm="1" />Code: Select all
<programmer exe="$(appdir)compilers\avr\batchfiles\avrc_arduinoA.bat" params="atmega32u4 avr109 com7 57600 "$(target).hex"" UsesComm="1" />Also check the COM port in the project options window is specified correctly.
