How interesting is the new PIC18 K40 series ?
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: How interesting is the new PIC18 K40 series ?
In my personal opinion these PIC18K40 devices are very interesting as we now see the start of implementation of core independent peripherals as they have been developing on the PIC16F1 series , The core independent peripherals is a very smart feature as it frees up the core for processing power and not driving the peripherals you only need CPU cycles when you write or change values to the peripherals These PIC16F1 devices are smart devices
with that said about the core independent peripherals the next is the feature rich and smart Peripherals they are having now such as the CLC, WWDTa ,Angular timers,math accelerator etc which allows a design engineer to use the mcu for processing and also it can be used to build interface hardware logic and other circuits these new peripherals are complex peripherals which you can do many things with depends on your needs I guess.
just an example the Math accelerator module allows you to use a PID loop in Hardware once setup /configured the cpu does nothing all is calculated in hardware and adjusted automatically imagine a PIC32MZ with this ability at 200MHZ what would its processing power be
The days of 8 bit mcu's is long not over and they have still many uses and will be there for a long time to come and the beauty here is these peripherals will find their way in to the PIC32 and PIC33's wow these things will be beauties to work with
You have to inform yourself about these new peripherals in order to understand what these new devices are capable of it is not easy to give you all the information in a single post
just my penny
just my penny
Regards QMESAR
Regards QMESAR
I'll get them on the list, they shouldn't be a big job to include but it depends how many new peripheral styles are included.
Right I've made a start, I'd like to have another pass as there are bound to be bits I have missed.
There are lots of new and different bits to these chips so expect problems. For example the I2C hardware peripherals now feature re-mappable I/O so this is currently unsupported.
I'm hoping I/O, DAC, ADC, SPI, UARTs and Timer interrupts should work ok.
Latest files included in the update here: http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18209
If anyone has a go then let me know how you get on.
Kenrix2
- Flowcode v5 User
- Has thanked: 72 times
- Been thanked: 177 times
Great job Benj. Thank you so much. Works perfect for me using the 27K40. I did expect ANSELA would be cleared in startup on this chip.
Not related to Flowcode but, I had an issue when using a LUT. After reading the errata I added the following right below "BEGIN" and problem solved.
Thanks again for all your hard work.
NVMCON1bits.NVMREG1=1;
Many thanks for letting me know,
ANSELA and other missing ANSELs have now been added to the init code as has the NVMCON1 command.
electron67
- Has thanked: 106 times
- Been thanked: 48 times
To working in Flowcode 6 the PIC18F**K40.zip
Enrique
Enrique
- QMESAR
The problem is not with MATRIX to include the new devices the problem is that the boostC compiler people does not include new devices very often and for that reason it can take a very long time if ever they will get support in the boostC compiler,electron67 wrote: To working in Flowcode 6 the PIC18F**K40.zip![]()
If you really want to use these devices then my advice would be to upgrade to FC7 as it is using the Microchip Compiler devices get added to the compiler automatically as they are released and MATRIX update FC faster
Regards QMESAR
Regards QMESAR
- QMESAR
Just one of the great feature of the"K40" series most of the things we normally need to do in hardware and software are all included and Part of the ADC now
- 1.JPG (21 KiB) Viewed 10868 times
- 2.JPG (44.97 KiB) Viewed 10868 times
Regards QMESAR
Regards QMESAR
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Just whilst waiting for some devices to test
Is anyone currently successfully using (Flowcode V7) UART on the K40?
EDIT:
Just got a PIC18F47K40 and both UARTs work fine
Seems that there is a possibility of a silicon error with (early) K40 and the use of strings and arrays.
EDIT:
