Programming to chip EB-006-00-6
alanwms
Has thanked: 4 times
Been thanked: 17 times
Post by alanwms »
V7 Programming a (new) chip PIC18F2553 creates compiler error message indicating:
1.Board voltage too high
2.Board voltage too high
3.Flash memory not verified - may be due to code protect.
FINISHED
Chip is not programmed.
Flowcode 5 programs these just fine. Can you investigate?
Re: Programming to chip EB-006-00-6
Sorry for the delay.
Flowcode v5 used a programming tool called PPP.
Flowcode v6 and v7 use a programming tool named mLoader. mLoader should work exactly the same way but it could be we have made a mistake in the config file for the device your using. I'll see if we have a 18F2553 chip available.
Just for sanity's sake does the chip still program ok via Flowcode 5 to double check that the chip has not had some kind of hardware failure.
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
Another possibility is for you to use PPP within Flowcode 7.
Instructions on how to set this up are in the Wki here:
http://www.flowcode.co.uk/wikiv7/index.p ... (PICmicro)
alanwms
Post by alanwms »
Flowcode 5 programs the chips just fine.
