I have a problem with the 18f46k22 chip and reading an analogue input as a 10 bit resolution ( 0 - 1024).
Microchip specify the analogue inputs a being 10 bit.
However if I read it as an integer, I only get a value of 0 thru to 255. Which is a byte.
I am using an external voltage ref set to 1.5 V.
Any help would be appreciated.
18f46k22 and analogue inputs
Roy Johnston
- Flowcode V4 User
- Has thanked: 2 times
- Been thanked: 34 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: 18f46k22 and analogue inputs
Please post the Flowchart you are using it will help people here to help you, when Microchip specify 10 bit it is 10 bit of that you can be sure
Regards QMESAR
Regards QMESAR
Roy Johnston
- Flowcode V4 User
Thanks for your reply, I was about to post my flow code. when I realized I had a problem with my code elsewhere, it is working.
thank you
thank you
