HI
I am trying to use the RFID component RC522 Via SPI
I have connected as Follows
SDA --> SS PK6
SCK --> SCK PB1
Miso --> MISO PB3
Mosi --> MOSI PB2
RST --> PK7
3.3v --> 3.3V
GND --> GND
I am duing: init MFRC522 --> MRFC522 Antenna ON --> MRFC522 Check for card
it always returns a value of 255 from Check Card
RFID MRFC522 not working on Arduino 2560 (Solved )
Re: RFID MRFC522 not working on Arduino 2560
Hi Alan,
Investigating this now.
Hi Alan,
I started investigating the component, the source project I was using as an example for the code has changed a lot since I last looked and it wasn't the best to read back then. It's pretty horrendous now.
The component as is is known to work so I wonder what might be going wrong. What type of RFID tags are you using and can you attach your program so we can try and replicate your setup.
Re: RFID MRFC522 not working on Arduino 2560 ( Solved )
Hi Benj
Another 2 modules just arrived today and they work perfectly
so it was the first module faulty ,
my apologies for your time & thanks for tying to help anyway .
