Need Help : 7 segment LED displays and PIC
hurdle_run
Has thanked: 2 times
Been thanked: 1 time
Post by hurdle_run »
I am a hobbyist and a newbie in graphical microcontroller programming. I discovered Flowcode lately, which has I think the most user friendly and easy to understand graphical user interface.
While exploring Flowcode I came across with a hurdle, actually I am trying to build a simple 2-digit counter and for that I am using PIC16F877A mcu. I agree that it has many input/output pins but I wont be working with the same MCU every time and hence don't want to spare 18 input/output pins just for driving two 7 seg LED displays.
I came to know about a technique called multiplexing but not sure if it could be implemented with Flowcode. If yes then kindly show how it could be done. I am attaching the piece of software I made so that it may be modified accordingly.
(297.85 KiB) Downloaded 1503 times
(299.43 KiB) Downloaded 1503 times
7 seg counter.fcf
2-DIGIT COUNTER
(10.5 KiB) Downloaded 727 times
Re: Need Help : 7 segment LED displays and PIC
It certainly is possible. This should help.
http://www.flowcode.co.uk/courses/itm/in ... imingRight
Flowcode v7 is far superior to v5 and there is a free 30 day trial available if you want to have a go with the latest version.
http://www.flowcode.co.uk/flowcode/
hurdle_run
Hi Benj,
Thanks a lot for the suggestion.
I've added a better multiplexing example here.
http://www.flowcode.co.uk/wikiv7/index.p ... 633f7cf892
Each time the timer interrupt fires it activates a single 7-segment display. Allowing a multi digit numeric value to be shown across several 7-segment displays.
hurdle_run
Thanks again Benj,
Sorry for the delayed response, I am out of station hence didn't check the software u made. I will definitely let u know my progress after a few days.
Thanks and regards
I didn't like the way that the multiplexed 7-seg displays were working in simulation and so I have played with the component and improved the multiplexing support.
The simulated display will now stay active for up to 100ms after being cleared and so now provides a much nicer flicker free display for use in the simulation.
Have a play and let me know how you get on.
Simply copy the attached file into your "Flowcode 7/components" directory and restart Flowcode.
led_7seg_single.fcpx
(12.27 KiB) Downloaded 649 times
I've now added another 7seg multiplexing example to the wiki, this time to create a stopwatch accurate to 0.1 of a second and counting up to a maximum of 999.9 seconds.
http://www.flowcode.co.uk/wikiv7/index.p ... :_Segment)
