PIC18F25K42
Kenrix2
- Flowcode v5 User
- Has thanked: 72 times
- Been thanked: 177 times
PIC18F25K42
I just received the new PIC18F25K42 and it would be nice if there was a ".fcdx" for this micro. So many new features on this micro like DMA, buffered SPI, controlled current I/O's plus hardware averaging ADC.
Re: PIC18F25K42
The device is not supported by the current PIC compiler in Flowcode v7 but I will see if we can use a later compiler in the next update and get this device supported for you.
Yes this looks possible, unless I find a major issue the next update release will contain XC8 version 1.41 and will have the new K42 devices included.
Kenrix2
- Flowcode v5 User
Re: PIC18F25K42
Thanks Benj.
Just a heads up. There is a typo in an ignorable compiler warning text when setting up this micro for midrange compatible interrupts. It warns it will write a reset instruction at low priority interrupt vector 0x8 but, the compiler correctly writes it to 0x18. Interrupts work as expected.
