In FC4, when I use a component RS232 I saw in simulation a window with the characters I sent. (see attachment)
Where can I find this window in FC6?
Thanks in advance for your help
simulation window RS232
dirkvg@skynet.be
- Flowcode V4 User
- rs232.fcf
- (5 KiB) Downloaded 380 times
- rs232.jpg (63.3 KiB) Viewed 10348 times
Re: simulation window RS232
In Flowcode 6 textual data appears in the console window.
If you use a human interface injector component then this allows you to create the field you can type incoming data into.
There are some examples here that should help.
http://www.flowcode.co.uk/wiki/index.php ... ccfa4c5efc
