inherited auto maping pin from RS232
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
Camille
Has thanked: 5 times
Been thanked: 3 times
Post by Camille »
Hello all
I'm trying inherite the TX and RX pin when channel hardware RS232 is selected.
In my properties panel component i need to selected to time channel hardware(channel1) for refreshing my TX RX pin component don't know why?
RS232_Menier3.fcfx
(19.1 KiB) Downloaded 475 times
Re: inherited auto maping pin from RS232
We have recently massively simplified this in v7 and you can right click a property and bring it through to be exposed in the component.
In v6 you have to do things the hard way which is manually copying the values back and forth.
Look at the CAL UART example here and hopefully that should help to show you what you need to do.
https://www.matrixtsl.com/wiki/index.ph ... Components
Camille
Post by Camille »
thanks for fast responce!
I take a look on cal UART coMponent it seeM not have auto hardware pinning TX RX, I'M wrong?
Camille
Post by Camille »
I'M wrong it is auto Maping
I investigate...
Camille
Post by Camille »
thank you,
it's solved with the flowcode 7 CAL UART example.
i iMpleMented soMe csv Macros...
RS232_CAL_SOLVED.fcfx
source
(87.1 KiB) Downloaded 457 times
RS232_Menier.fcpx
coMponent
(7.54 KiB) Downloaded 442 times
