flowcode V7.2
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
flowcode V7.2
What system requirements are required for v7.2 ?
My trusty old laptop doesn't like it Compaq Presario CQ61 4 gig ram when I open flow code with nothing else running only background stuff it struggles and has a very high cpu usage (98% +)
Run 7.1.1 ok
Run 7.1.1 ok
Re: flowcode V7.2
Hi Steve,
It's shouldn't be too different from version 7.1 in terms of system requirements. Does it always use 98% even when starting with a new project or is it only when opening specific files that it goes this high?
Maybe linked with a specific component or something else specific to a project?
Steve001
Re: flowcode V7.2
Hi ben,
Not got that far its when flowcode loads and waiting for the start page, have found it settles down after about 2 mins if i leave it alone
Do i have an excuse for a new laptop
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: flowcode V7.2
Hi Steve,
it really shouldn't take that long so I think something is interfering. Have you tried running the PC in safe mode and trying Flowcode?
If you suspect the welcome page is taking a while, there could be something in your IE settings that is preventing the download of information from our website.
Steve.
Steve.
Re: flowcode V7.2
Do you need an excuseDo i have an excuse for a new laptop
Would be nice to keep it handy for now though so we can try and work out what's going wrong. Out of interest what version of Windows are you running.
Steve001
Re: flowcode V7.2
running win 7 home 64 bit
Runs ok on pc but that's a bit more beefy with same version of windows
"Charlie ben says I need a new laptop ...
Steve001
Re: flowcode V7.2
Evening
after a few tests found it is norton related not sure whats going on nis.exe shows 0%
If i disable norton flowcode starts quite quick
The attached program also makes it think for some reason cpu bouncing around 45 - 58 %
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Re: flowcode V7.2
I use Norton and have not noticed this behavior, but i can keep eye on my system if i find similar symptoms.
My computer might be too beefy so haven't noticed
Re: flowcode V7.2
Hi Steve001
Replacing your Hard Disc with a solid state One ( SSD ) should make your Laptop about
10x faster , i use Flowcode 7.2 on an old Core2 duo with 2gb of ram but have an SSD
installed windows 8.1 32bit , Flowcode 7.2 runs perfectly and takes about 20 to 25 Seconds
to open a 900kb FCFX file .
Steve001
Re: flowcode V7.2
Not noticed on my PC either runs all fineEtsDriver wrote:I use Norton and have not noticed this behavior, but i can keep eye on my system if i find similar symptoms.
my laptop is older than yours have tried two different SSD's the bios dosn't pic them upAlan_37 wrote: Replacing your Hard Disc with a solid state One ( SSD ) should make your Laptop about 10x faster
