error code -1
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
error code -1
I have probleme to compile.
Change short and long name no succsess
Any ideas
Regards wolfgang
Any ideas
Regards wolfgang
- error code.GIF (116.93 KiB) Viewed 13591 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: error code -1
What version of Flowcode are you running? (Menu Help->About Flowcode)
Could you look in your Flowcode7 installation directory, in \compilers\STARM\batch and see if you have the file F429Disco.bat
saschech@gmx.de
Re: error code -1
hello
- batch.gif (20.86 KiB) Viewed 13585 times
- vers..GIF (9.44 KiB) Viewed 13585 times
saschech@gmx.de
saschech@gmx.de
Re: error code -1
hi LeighM
I install on my laptop v7 also and have the same problems to compile the arm-projekts.
with the pic no problem.
Regards wolfgang
Regards wolfgang
- compile ok.GIF (172.07 KiB) Viewed 13573 times
- LeighM
Re: error code -1
Strange.
Does an AVR target compile, e.g. Arduino Uno?
This FAQ might help ...
http://www.flowcode.co.uk/faq/index.php? ... artlang=en
saschech@gmx.de
Re: error code -1
After new install with eneable 8.3 compiler is ok,but I have a new error
Regards Wolfgang
Regards Wolfgang
- new error F746.GIF (124.54 KiB) Viewed 13563 times
saschech@gmx.de
- LeighM
Re: error code -1
The gLCD has to match the target device.
You cannot use the 429 gLCD with 746 device.
Have a scroll through the gLCD components and you will see the correct display for whichever Discovery board target you want to use
saschech@gmx.de
