esp8266 examples
Re: esp8266 examples
The TCP server example here should hopefully help.
https://www.flowcode.co.uk/wikiv7/index. ... (Wireless)
The example should work with v6 but let us know if not.
Hello, I want to know if is necessary to use a LCD with ESP8266 ??
Is possible to use a pic 16F88 or 877A in 4Mhz??
Thanks !!
Thanks !!
No it's not nessisary. Just useful for debugging. LEDs could be used instead i fyou need some sort of indication?I want to know if is necessary to use a LCD with ESP8266 ??
I think you will struggle with these devices as they don't have a lot of memory available and 4MHz is pretty slow. But with very simplistic webpages and small buffer sizes it should be possible. At 4MHz you might not be able to acheive the 115200 baud required by the module?Is possible to use a pic 16F88 or 877A in 4Mhz??
