STM32 ARM UART
Re: STM32 ARM UART
I am not sure about the conclusion when using NUCLEO-F746ZG :
Is there a chance to connect the USB directly to a PC and get serial communication
or is a separate USB serial card needed ?
Best regards
BO
Best regards
BO
- Has thanked: 182 times
- Been thanked: 179 times
- Has thanked: 6 times
- Been thanked: 44 times
Re: STM32 ARM UART
stefan.erni is correct. The Nucleo-F746ZG (and probably all other 144-pin Nucleo boards) use USART3, TX = PD8, RX = PD9 for the USB UART. No links or modifications are required.
I will edit my earlier post to include this information.
The information for the Nucleo boards seems to apply to all chip options of each pin count (32-, 64-, 144-pin).
Discovery boards not in the list will need to be checked individually for access to this feature.
Re: STM32 ARM UART
Thanks,
It seems to be in the right direction,
but I can't confirm functionality.
I also don't understand what SB4....SB7 means
- NUCLEO-F746ZG_UART2.jpg (65.78 KiB) Viewed 18565 times
Re: STM32 ARM UART
Yes, everything seems OK
Still, I can't serial-communicate with PC over USB
That's why I keep searching for something that might be missing
The solder bridges SB4 and SB7 should be removed, but if pin D8 D9 are not used,
they could probably stay
Re: STM32 ARM UART
Hi PicoPuls
If You start on the another way, it's more comfortable. The Nucleo is sending nonstop and You can just change Parameter or what ever on the computer. You can also see if You receive character in a wrong Baudrate. When it once works switch to your program.
Re: STM32 ARM UART
Thanks for the idea! Digilent-410-212
The Flowcode UART code has two connections TX, RX
and the Digilent unit has 4 connections TX,RX, RTS, CTS
Should RTS, CTS just be connected to GND ?
- Digilent-410-212.jpg (137.39 KiB) Viewed 18532 times
