circuit diagram for the e-block093 (arduino uno shield)
astro1234
Has thanked: 39 times
Been thanked: 13 times
Post by astro1234 »
Is there a circuit diagram for the e-block093(arduino uno shield),
as i need to know which pins go to the outputs sockets.?
there is no diagram in the pdf file for this board.
Regards astro1234.
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Re: circuit diagram for the e-block093 (arduino uno shield)
Post by johnsondav »
Hi astro1234
There are a great many resources to be found in the 'Learning' center for many of the Flowcode modules. However, here is the data sheet that hopefuly explains what you require:
The EB093 Arduino Sheild
EB093 Aeduino Compatible Shield.pdf
(263.47 KiB) Downloaded 283 times
D-SUB Connectors
D SUB Connector.pdf
(210.83 KiB) Downloaded 283 times
Hope to helps.
Dave
astro1234
Post by astro1234 »
johnsondav wrote:Hi astro1234
D-SUB Connectors
D SUB Connector.pdf
Hope to helps.
Dave
Thank you for the files, but if you look at the pdf file for the board there is no circuit diagram ,example what pins on the arduino
go to the what pins on the rs232, so i got the meter out
and found out which pins are what, it as a bit of a weird layout.
What i am doing is connecting the eblocks to the arduino,and then running and operating them from labview.
Regards astro1234.
