Hi Benj,
I am new to FC6. Recently I have also upgraded to FC7. I put below C code in the main() intended to set the port pulled high internally.
LATG |= 0xc0;
However, after compilation and tested the hardware, the port is not pulled high. Can you tell if I made any mistakes?
Thanks a lot
Allen
C Code in PIC
allenkkwong
- Has thanked: 1 time
- Been thanked: 3 times
Re: C Code in PIC
Hi Allen,
What chip are you using?
When you say pulled high do you want to output high or simply pull up high using the internal pull up resistors?
The output high will give you 20mA of pull, the internal pull up's will give you significantly less that this in terms of current.
allenkkwong
Re: C Code in PIC
Hi Benj,
I am using PIC18F67J111. I want to simply pull high using the internal pull up resistors.
For the current, I understand this. I do not need high current.
Thanks.
Thanks.
allenkkwong
Re: C Code in PIC
Hi Benj,
I am using PIC18F67J111 and want to use the internal pull resistor.
I do not need high current and understand that the current is less than 20mA which is far more than required.
Re: C Code in PIC
The following applies to the PIC18F67J11 device family and Flowcode 7. The Weak pull up is usually something like 100K Ohm though this can vary from one device family to the next. 80uA - 400uA specified in the datasheet.
To enable PortB pullups.
To enable PortD pullups.
To enable PortE pullups.
To enable PortJ pullups.
INTCON2 &= 0x7F;Code: Select all
PORTG |= 0x80;Code: Select all
PORTG |= 0x40;Code: Select all
PORTG |= 0x20;Regards Ben Rowland - MatrixTSL
allenkkwong
