Hi all
Writing of bits to any of the B port pins is not recognized. Writing to ports A or C is fine.
This is on my target hardware which is a PIC16F18855.
Any ideas?
Howard
FC7.2.1.4
Port B not working
Re: Port B not working
Hi Howard,
I've just tried this and it's working ok for me. Can you post a Flowcode project file that shows the problem and can you also post the contents of your compiler messages showing the errors so we can investigate.
Hi Howard,
Working for me as well.
Have you downloaded, copied and paste all files within zip file from this post?
howard123
- Has thanked: 30 times
- Been thanked: 28 times
Hi Ben and Martin
I had installed those updates some time ago. There is no compiler error message.
I am using a PicKit 3 to target the device and this uses RB6 and RB7 for its communications. This works fine and later, with the programmer disconnected, RB7, RB6, RB5, RB4, RB3, RB2, RB1 and RB0 work only as outputs . They do not recognize an input.
I have attached my test
Howard
Howard
- test1.fcfx
- (6.87 KiB) Downloaded 273 times
Hello Howard,
The low voltage programming is enabled in your configuration settings. This will likely stop one of the PORTB pins from working as an input. I would highly recommend disabling this feature.
You have your oscillator set to external clock, is this the case on your circuit? You might instead want HFINTOSC to try the internal clock without any external requirements?
howard123
Hi Ben and thanks for the speedy response once again.
Unfortunately that did not work for me. My apologies as my example was more illustrative than functional so here is something more robust.
I have used a byte wide input rather than bits and compared Port A to Port B.
In test1 raising any Port B pin to high has no effect on the RC3 output - it remains low.
In test2 raising any Port A pin to high causes RC3 to go high.
Howard
Howard
- test2.fcfx
- (7.23 KiB) Downloaded 281 times
- test1.fcfx
- (7.23 KiB) Downloaded 271 times
Hi Howard,
I believe the problem is the definition file which was leaving PortB in analogue mode which basically kills digital inputs. It's been fixed in the definition files I have here but maybe I have not released these yet. I'll try and add a new zip file to the forum updates this week.
This file should hopefully solve the issue for you. Simply copy to your "Flowcode 7\FCD\PIC" folder and restart Flowcode. Let us know how you get on.
