Problem with component sensor Temperature Humidity (DH11)
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
streammaster
Has thanked: 7 times
Been thanked: 13 times
Post by streammaster »
Hi guys,
I believe that the sensor component for DH11 has a bug:
It appears that the string values are correct (for humidity and temperature), but the floating for humidity returns the temperature values instead.
Can you tell me if a user can edit flowcode component and how in order so I can fix this by my self?
Thanks,
Igor
Re: Problem with component sensor Temperature Humidity (DH11
Hi Igor,
Many thanks for letting us know of the problem, the attached component should solve the issue for you. Simply copy the file to your "Flowcode 7/components" directory and restart Flowcode.
DHT11.fcpx
(35.5 KiB) Downloaded 352 times
I have moved topic to Bug reports section as it is a reported bug.
streammaster
That definitely fixed it.
Thanks for doing it so quickly.
