array access in C code
nils
Post by nils »
I am using the AVR programmer with an Atmega32 and the LCD E-Block. Then I use the Custom Component to implement a lookup table called aSineWave inside the GetDefine dummies.
In the Custom Component function TestWave I try to access this array, but I do not get anywhere. I tried to print it out on the LCD, but it seems to be everytime 0 and am now out of options to get it running, so that I would like you to have a look at the Flowcode file and my edited Custom Component file.
thanks in advance
cheers,
nils
PS: I will use this later on to feed a DAC chip with the SPI, and found out that nothing changed at the SPI output :/ and sorry for posting it first in the ARM forum, was a bit confused yesterday because of this not so trivial problem.
edit: see next post for my files.
Custom_Code.c help needed? -> http://tinyurl.com/2y2mzq
Flowchart high quality vector graphic output =>>http://tinyurl.com/6sx2sx
nils
Re: array access in C code
Post by nils »
hi again
I just wrote a very small C program to see what was going on, because I couldn't get it running with the microcontroller. first I have to achknowledge, that I should have set the variables to both unsigned char to avoid any confusion with signed values. changing this, the output on my computer just looks fine, and I have no clue why this is not working on the LCD, because it seems as if every value of the array is zero, which it is definitely not.
now I attached my sample Flowcode program including the updated Custom Component code and the C program which tests the array output.
still I have no idea how to resolve this problem :/
cheers,
nils
Archive.zip
(5.56 KiB) Downloaded 671 times
Hello Nils
Are you simulating or running your program on the hardware? C code cannot be simulated from inside Flowcode.
nils
Post by nils »
yes, I already came across this pitfall when I began using C code ;) I am not simulating now and working with the actual hardware bits: AVR programmer and LCD E-Block.
I do have really now clue what is going on with arrays implemented in the Custom Component, so I tried to do the same thing without the controller but in pure C on the commandline. et voilΓ , it works on the commandline!!
what I tried next was putting the array inside my Custom Component function, but this had the same result.
so what I wanted to do was:
- going through the array step by step
- assigning to the tmp variable 128 + actual array value
- displaying tmp on the LCD
- delaying the for loop
and I expected to show something like this:
128 <255ms later> 129 <255ms later> 130 ... and so on
and I got
128 <255ms later> 128 <255ms later> 128 ...
which tells me, that the array values HAVE to be zero and I have no clue whatsoever what is going wrong.
hope this clears something up, if you have further questions, just ask. thanks for your help in advance
cheers,
nils
nils
Post by nils »
ok, here it comes. after I took a look in some FAQ' about AVR gcc I found the answer I was looking for. I have no idea why it doesn't work the other way round.
// this include is needed, to get access to the program functions
// and special keywords
#include <avr/pgmspace.h>
// table for sine wave of the first arc from 0 to pi/2
const unsigned char pgmSineWave[] PROGMEM = {0,
1,3,4,6,7,9,10,12,14,15,
17,18,20,21,23,24,26,28,29,31,
32,34,35,37,38,40,41,43,44,46,
47,48,50,51,53,54,56,57,58,60,
61,63,64,65,67,68,69,71,72,73,
74,76,77,78,79,81,82,83,84,85,
87,88,89,90,91,92,93,94,95,96,
97,98,99,100,101,102,103,104,105,106,
107,108,108,109,110,111,112,112,113,114,
115,115,116,117,117,118,118,119,119,120,
121,121,122,122,122,123,123,124,124,124,
125,125,125,126,126,126,126,127,127,127,
127,127,127,127,127,127,127};
void TestWave(){
/*Macro_TestWave_Start*/
	int i;
    unsigned char tmp;
	for(i=0;i<=127;i++){
   		tmp = pgm_read_byte(&pgmSineWave[i]);
  	 	FCD_LCDDisplay0_PrintNumber(tmp);
		delay_ms(255);
		FCD_LCDDisplay0_Cursor(0, 0);
/*Macro_TestWave_End*/
This code shows basically my test function to see output on the LCD, and now it works like a chamr when using the special functions and constructs. hope I could help. If any questions arise, don't hesitate.
cheers,
nils, who is now going to implement the sine wave generation into his DAC project :-D
references:
http://www.nongnu.org/avr-libc/user-manual/ and in german
http://www.mikrocontroller.net/articles ... 28Flash.29
