Medelec35! RTC **SOLVED**
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi Martin!
I am making a project with an Arduino Mega, ILI9341 and a SHT21. It work fine. I would like to use your nice program from here: viewtopic.php?f=26&t=16392 with RTC. I have tested your program with diffrent devices Pi16f876 and 877
ect. It work fine. I import your program in my program but cant get time, date year ect read out.
I think the issue is you use a 19mhz Xtal and the Mega use 16Mhz Xtal, so there is something with the timing. Is it possible to change something in your program so it is possible to use it in Arduino mega? Please.
Thank´s in advance
BR Jorgen
IlIDisplayTestSHT21VUR1.fcfx
(110.56 KiB) Downloaded 161 times
DS1307 RTC Tester & Programmer V1.fcfx
(67.4 KiB) Downloaded 155 times
Re: Medelec35! RTC **SOLVED**
Hi Jorgen,
Glad you have solved your issue
If you are interested in the RTC being set from date and time on your PC using an App, then take a look here
jgu1
Post by jgu1 »
Hi Martin!
Thank you. I will look in the exambles. Thank´s
By the way, very nice project you made... :D
Br Jorgen
