STM32F469 discovery cannot compile WLAN component
achillis1
Has thanked: 91 times
Been thanked: 8 times
Post by achillis1 »
hello,
I try to send a blank flowcode to the STM32F469 screen and it compiles correctly.
When I add the wlan esp8266 component then I get an error; I attach it.
Thank you
Best Regards
Andreas Achilleos
STM.txt
(6.21 KiB) Downloaded 238 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: STM32F469 discovery cannot compile WLAN component
Post by LeighM »
Could you attach your example, it might be a properties issue, such as uart channel?
achillis1
Post by achillis1 »
Hello Leigh
I am attaching the file but I think is best to send me a file that you know is correct.
The file I am sending is blank and only the wlan component is added
I get the same error with every compination. For example, usart channel 1, channel 2 ,wlan macro added "initiate ()", baud rate 9600.115200, Tx Rx pin remap or not.
Thank you
ESP8266_CreateAP.fcfx
(9.54 KiB) Downloaded 270 times
LeighM
Post by LeighM »
Works for me, maybe you have older files, there are updates here...
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18760
Latest attached, FCD in particular.
Could you try these.
Leigh
WLAN_ESP8266.fcpx
(24.96 KiB) Downloaded 266 times
32F469Discovery.fcdx
(33.9 KiB) Downloaded 235 times
ESP8266_CreateAP_Ch1.fcfx
(9.71 KiB) Downloaded 244 times
achillis1
Post by achillis1 »
Hello Leigh
Thank you for the reply.
What about the .fcdx & .fcpx extension files? They are not recognizable by Flowcode.
Thank you
LeighM
Post by LeighM »
*.fcpx need to be copied into you Flowcode components directory
*.fcdx need to be copied into you Flowcode FCD\ARM directory
