i tried to implement a c code in flowcode but it showed some errors regarding the floating point value operations.
it does not support float to int conversion.
it gives the following errors on compiling the prog.
float val=0;
int i;
val=FCV_ADC_VALUE*5;
val=val/1024;
val=val*1000;
i=val;
FCV_ADC_VALUE=i;
ERRORS:
operation '=' using operands 'float' and 'float' is not supported
can't convert 'float' to 'signed int'
C in flowcode
Re: C in flowcode
Which version of Flowcode are you using (PIC/AVR/ARM)?
raghavmonga
Re: C in flowcode
This guide to the Floating point libraries should help you to get started with floating point numbers.
http://www.matrixmultimedia.com/support ... .php?t=505
