PIC16F18345 EEPROM Compiler problem founded
Re: PIC16F18345 EEPROM Compiler problem founded
For correct analysis use the attached files. Disregard the other files in the analysis. They had setup errors, but the problem remains the same.
- TEST PICF18345 T2.fcfx
- (7.34 KiB) Downloaded 260 times
- TEST PICF18345.fcfx
- (7.33 KiB) Downloaded 260 times
Hi Danilo.
Sorry, I have never used PIC16F18345.
So I don't feel confident I can assist.
Perhaps someone else who knows about your microcontroller can help further.
Martin,
Many thanks. Perhaps Benj could give me some help. I have sent a message to him.
Thanks a lot.
Thanks a lot.
First of all can you make sure you are using the latest files.
1) the EEPROM CAL file needs to be placed into the "Flowcode 7/CAL/PIC" folder.
2) the device definition file needs to be placed into the "Flowcode 7/FCD/PIC" folder.
This should hopefully then work correctly. I've tested the new code on a 16F18877 which is a similar family and this is working really well.
Let us know how you get on.
Dear Benj,
Now it works. Many Thanks!!!
Question: I know that on FC6 the view asm exist, but on FC 7 it isn´t. Is it possible to have on FC7 the .asm? it will be very helpfull for debugging.
Brgds,
Brgds,
Brilliant glad it's working for you, thanks for letting us know.
There is a .as file that's created in the project directory that contains the assembler code.Question: I know that on FC6 the view asm exist, but on FC 7 it isn´t. Is it possible to have on FC7 the .asm? it will be very helpfull for debugging.
