Keypad (Hex 4x4) Bug
Value of keys to interchange
- Should be 11
- ERR B to 11.jpg (200.43 KiB) Viewed 6962 times
- Should be 10
- ERR A to 10.jpg (192.49 KiB) Viewed 6962 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Keypad (Hex 4x4) Bug
Thanks for spotting that.
Fixed component attached, please copy this into your Flowcode 7 installation components directory.
- keypad_hex.fcpx
- (2.21 KiB) Downloaded 243 times
Hi Osta.
After replacingwith version Leigh posted and Reloading flowchart:
Working correctly with external simulator and Flowcode simulator.
Sorry, I have to disagree with you.Osta wrote:Everything remained unchanged .......
After replacing
keypad_hex.fcpxWorking correctly with external simulator and Flowcode simulator.
Hello!medelec35 wrote:Hi Osta.Sorry, I have to disagree with you.Osta wrote:Everything remained unchanged .......
After replacingwith version Leigh posted and Reloading flowchart:Code: Select all
keypad_hex.fcpx
Strange, but I still have ....
Martin!
I am very sorry !!!!!
Was wrong !
Wrong with the folder!
Everything is working !!!!!!!
I bring my apologies !!!
Was wrong !
Hi Osta,
Not a problem at all.
So long as all is working as expected.
Thanks for the update.
I like the way you customized the calculator keypad.
You using Proteus 8.7 beta yet?
It's not a bad version but some crashes.
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
FYI
I am using 8.7 SPI 1 on WIN10 and WIN 7 it seems ok no crashes and runs fine nice things added to 8.7
Regards QMESAR
Regards QMESAR
Thanks guys.
I noticed that the updates for SP1 was for IoT Builder issues.
I did not install because I don't use it.
But maybe it will fix the random crashes, so now running 8.7 sp1.
