Lambda fuel injection controller
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Re: Lambda fuel injection controller
not done a flowcode one, but a friend has built a ECU take a look here .
http://www.megasquirt.info/
steve
steve
Hi jjw,
I have had a look at the flowchart you sent via PM.
As using LCD, 3 x 7seg and ADC:
For your project to work you will require 16 outputs (DP not connected) and 1 input (must be ADC)
As you're using 16F1825, it only has 11 outputs/inputs and 1 input only which is not ADC, Project will not work.
The common pins of LED display must have their own separate pins.
Its the A - G & DP which all can be connected together.
There are various other issues with flowchart that will require sorting out.
Best to sort out a more suitable target device first, then we can take it from there.
@Steve that does look interesting.
How is the ECU working for your mate?
Yes it has enough pins.
However you configured 16F1825 to use an internal oscillator.
Unfortunately 18F252 does not have one.
Are you going to change device, or use crystal or resonator instead?
Wow Megasquirt is still going - great piece of kitSteve001 wrote:not done a flowcode one, but a friend has built a ECU take a look here .
steve
So how do you want the 3 x 7seg display to work.
For example if you have 22.32V showing on the LCD, what has the LED need to display?
You had the d.p disconnected(you also had seg g disconnected: I will connect it as it only uses one more pin (i already connected g when mentioned how many pins required).jjw wrote:There is no need to show more than one digit after dp 22.3 is enough in our purpose.
Hi JJW,
I have sent you an updated flowchart via pm.
With V7 you can set each segment with any pin: Martin
You can only have a whole port for the segments with Flowcode V5.jjw wrote: Noticed at the very beginning that I couldn’t change the pin orientation in FC as it was in scheme. Is it even possible to have different ports for 7-segment display?
Hi Jukka,
Glad its working for you.
Thanks for the update.
