Creating time mark output
Any general or miscellaneous queries that do not fit into the other forum catagories
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
I need to create a time mark pulse at around 1mSec intervals, but not constant, it varies a bit.
I was planning to use a timer int to increment a counter. So far so good, but I also use several delays in the program. The time mark int should occur even during a delay.
I don't know which timers Flowcode uses to set a delay. How do I make sure that it doesn't touch my timer that I use for the time marks (for instance TNR0)? Can I specify which timer it should use for delays?
TIA,
Jan Didden
Has thanked: 114 times
Been thanked: 422 times
Re: Creating time mark output
Post by Steve »
Simple answer - Flowcode does not use a timer to generate a delay using the Delay icon.
jadiflow
Flowcode v5 User
Post by jadiflow »
OK, clear. So, while in a delay, I continue to receive interrupts (if they are enabled, of course)?
Thanks,
Jan Didden
Post by Steve »
Hi Jan,
Yes - that is correct.
