Another Adafruit 20x4 LCD component bug
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
keithh534
Has thanked: 15 times
Been thanked: 12 times
Post by keithh534 »
When compiling to chip, display doesn't work.
I believe the issue is it's missing 2 lines of code in the "Start"method.
Currently, it looks like this:
(17.99 KiB) Downloaded 1562 times
It should look like this (missing code highlighted):
(41.65 KiB) Downloaded 1562 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Another Adafruit 20x4 LCD component bug
Post by LeighM »
Thanks.
I've had a look at the Adafruit Arduino reference code, and you are correct, it shows an extra 0x08 for V2 only,
So I've added this on a new property OLED V2 no/yes.
Although the Adafruit gives the order as 3,8,2,2,8 rather than 3,2,8,2,8 so I've implemented it as Adafruit sequence,
let me know if it does not work for you.
Leigh
LCDAdafruitOLED4x20.fcpx
(25.53 KiB) Downloaded 257 times
keithh534
Post by keithh534 »
Leigh,
Thank you for the effort, but the only difference I see is the removal of what appears to be debugging code.
(24.22 KiB) Downloaded 1541 times
Keith
LeighM
Post by LeighM »
Hi Keith,
In the LCD component properties you should now see a new property: OLED V2 no/yes
Set that to yes.
keithh534
Post by keithh534 »
That method doesn't appear in the list
keithh534
Post by keithh534 »
I take that back. I found it!
