I've been messing around with one of the tutorial demos where the LED module is used as a stop watch. Is there a way of blanking the left most digits (minutes) until they are used (more than 0)?
I'm just looking to make the display more readable in the dark and removing the leading zeros would be ideal.
Nick.W
Blanking the display (4 digit LED)
Re: Blanking the display (4 digit LED)
You should be able to use a decision icon to perform the functionality you require.
If you need more help then there is an online course available here that should get you up to speed.
http://www.matrixmultimedia.com/Learnin ... /index.php
