I did apply this patch but now FC crashes when it wants to write the program through the USB to the Arduino UNO. This worked correctly before. Any idea?
Maybe it is better to apply such updates as a full new install. There's always scope for errors having to unzip the package into different folders, and the issue of having to manipulate security settings for those folders where a simple user normally has no write access.
BTW Does this update cover the fixes to the PIC_CAL_ADC ref voltage settings?
Jan Didden
Linear Audio
Flowcode 7 - Updates Since 7.3 - Questions
Re: Flowcode 7 - Updates Since 7.3
I'm somewhat confused by the statement, "feature: Added CAL SPI/I2C support I2C family of devices e.g. 18FxxK42 Untested".
Does this mean that the CAL for the specific family of devices is untested or the CAL itself is untested?
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Added CAL SPI/I2C support I2C family of devices e.g. 18FxxK42 Untested".https://www.flowcodexchange.com/
Regards QMESAR
Regards QMESAR
Nope the changes listed above have come after the current 7.3 release of Flowcode. You can check back here for the latest bug fixes and improvements to apply to the 7.3 release build.i have downloaded the latest version of FC7.....does this also include all the updates/patches
as mentioned above?
Re: Flowcode 7 - Updates Since 7.3 - Questions
Hi Guys,
I'm away from my FC PC's with work, so cant pull up the Device list.
Is there a current document that lists all supported devices? (maybe across all platforms, PIC,AVR,ARM)
I'm looking at a small side project that the newer PIC16F series would be very good for but just wanted to check compatibility, then pick the hardware. J.
