Hi Team.
It seams there not going to be support on this LabVIEW issue
In any case here is a FC Firmware question
In the USB Request_Handler macro there is defined a String variable of b[20]in which the USB string is placed
question 1 where is this done in the code (
I seam to miss it I do not see this)
- 1.jpg (43.84 KiB) Viewed 23914 times
Question 2
Why is this string terminated the moment there is 0 in an elemment
example if string (byte array) 1,2,3,4,0,6,7,8 CAN buffer is populated with 1,2,3,4 the rest of the string is then missing
similar if the USB string (array contains ) 1,2,0,4,5,6,7,8 CAN buffer is populated withg 1,2 and the rest is missing
- 2.jpg (41.43 KiB) Viewed 23913 times
The same is true fro for the outgoing string(Miac to PC) if all elemenst are non zero it works fine ,when one element contain a 0 everything after the 0 is missing,
Please help me understand this as in many CAN messages 16 bit variables are send as a High and a low byte for example if the value is 200 the
the CAN Message will send High byte = 0 and the low byte = C8 if the Value is 500 the High byte = 01 and the Low byte = F4 as you can see
if the USB string is terminated(for example)when it contains a 0 in a byte element then the MIAC and USB slave control is no option for me and I should stop waisting my time on this as at the moment I am strugling with MATRIX Firmware and labVIEW supplied support files and very little support from the Team so I am asking myself is this worth it to carry on trying to sell MIAC's
Team let us make a dicision we fix this issue or we stop it but I have now waste 1 week all on my own with this labVIEW files and Leigh fixed the issue in the Firmware ( 2 fixes applied) I am prepared to to help and support but I can not fix these issue on my own struggling for weeks ,
I applogize if I sound rude it is not my Intension but I am frustrated I have a DEMO coming up with a Serious Institution regarding eBlocks and Miac and I will have to say red faced I did not mange to get the labVIEW support working this is not good for me or my company understand this too secondly if MATRIX do not want to support the labVIEW stuff for MIAC that fine too but then remove it from Datasheet as customers see this and ask for it
Once again I am sorry about this I realize I have been bugging you guys a lot with the labVIEW issue
