STM32F469 DISCO
Re: STM32F469 DISCO
Please can you attach your Flowcode project file and your bitmap images and we will investigate for you.
Re: STM32F469 DISCO
Here's a simple demo that should work.
Re: STM32F469 DISCO
The demo I posted worked well here. The bitmap file is quite large so you may get a message saying the Ev_Property event is taking a long time to complete, just let it do it's job of parsing through the bitmap file and then the sim and download should work as expected.
You could maybe try a smaller pixel size 24-bit bitmap or maybe try a monochrome type bitmap. in v7 only 24-bit and mono types are supported.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: STM32F469 DISCO
Did the program compile and download to the Disco board?that demo doesnt work on STM32F469 Disco board.
The demo looks like this ... As Ben mentioned, when loading or running the project in Flowcode you might get popups,
if you get one like this, click No ...
Re: STM32F469 DISCO
yes Benj you were right about 24 bit pictures, it is runing and also there is pop up error like LeighM said . But program works.
Did you try to set bacground color? It is always same.
Re: STM32F469 DISCO
To change the background colour try changing the colour and then call the clear function. This should redraw the entire background in the new colour.
