The compiler does not work !!!
This has happened before ! Deleted the project and started again everything was fine .
And here is again stopped work !!! Compiles HEX but this HEX is not working!
After as prescribed TRISE register....
I do not know what to do!!! Delete the project again and start over?
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: The compiler does not work !!!
Could you post the generated message file? (Attach the txt file to your message)
― C.S. Lewis
― C.S. Lewis
I did the right thing?
- TXT File.txt
- (1.54 KiB) Downloaded 223 times
The text message you posted is just stating your project has compiled OK.
The Hex file should have been generated.
Yes, the file is generated, but after programming the project that used to work, now does not work
I do not understand...
I changed nothing.
In the simulator Proteus also stopped working.
EDIT:
I will start this project again
To see the difference...
EDIT2:
I realized where I was wrong!
Thanks for the help !!!
Best regards Osta
I changed nothing.
EDIT:
EDIT2:
Best regards Osta
Reason: Edited multiple messages into one
