Hi Monie,
I've had another look at your program and made a suggested change, no interrupt needed.
Leigh
Global emergency stop via interrupt
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Global emergency stop via interrupt
- Miac Interrupt Emergency Stop-004.fcfx
- (33.4 KiB) Downloaded 252 times
Monie Jacobsen
- Has thanked: 17 times
- Been thanked: 46 times
Hi LeighM
Now the program works very well
Thank you very much for your great help.
Really good working day
Best Regard
Monie
Monie
Monie Jacobsen
Hi LeighM
Had to use Q4 - B7 for Reset [/ b] instead of B2 ?????
What's wrong here? See attached file: Wishing to be able to use KeyPad 5 = Noedstop and Keypad 3 = Reset, the place for loose contacts.
Have the same issues as above!
Is it something you would like to help correct so Keypad can be used?
See attached file:
See attached file:
Best Regard
Monie
Monie
