Hi LeighM
Had to use Q4 - B7 for Reset [/ b] instead of B2 ?????
What's wrong here?
Wishing to be able to use KeyPad 5 = Noedstop and Keypad 3 = Reset, the place for loose contacts.
Have the same issues as above!
Is it something you would like to help correct so Keypad can be used?
See attached file:
Error message for MIAC PIC
Monie Jacobsen
- Has thanked: 17 times
- Been thanked: 46 times
- Billede2.JPG (33.43 KiB) Viewed 14143 times
Best Regard
Monie
Monie
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Error message for MIAC PIC
Hi Monie,
It is not clear what you are asking.
Just some observations:
- Setting all ports to outputs in the main and interrupt routine could cause problems.
Only one key can be pressed at any one time, if you try pressing more you will get unexpected values.
Monie Jacobsen
Hi LeighM
I try again
Would you like to help with the attached coder to set KeyPad 5 = Stop and Keypad 3 = Reset.
I can not get the KeyPad feature KeyPad 5 or Keypad 3.
But with the external switches, the switching Stop or Reset works fine.
I try again
Best Regard
Monie
Monie
- LeighM
Hi Monie,
The relays/motor goes to Stop when the key is released,
this is because the no key pressed has value 255 and you have a test "if keyval > 9 then Stop".
Is that what you intended?
Maybe you should remove it?
Then add a test for KeyVal 5 in your "Switch KeyVal" and set Flag_Noedstop = 1
