Good morning Benj, in my project I am using the RS232 communication of the 24FJ1024GB610 microcontroller, my problem is that I do not get channel 5 and 6 defined by the chip as RS232 communicate. I enclose the file so you can see what the problem may be. Thank you very much for your attention.
regards.
Problem RS232 comunication channels 5 and 6
- PANTALLA TFT ILI9341 - RS232.fcfx
- (12.9 KiB) Downloaded 522 times
Re: Problem RS232 comunication channels 5 and 6
What version of Flowcode are you using?
Do channels 5 and 6 appear in the Channel list?
Are you getting compilation errors? If so what are they?
Could you maybe explain the problem in a bit more detail as this will help me to pinpoint what I'm looking for.
The version I use is the last V8, the problem is not that it does not compile, the problem is that when I compile and program the microcontroller I can not send or receive data through channels 5 and 6 of the micro. These are the ones defined for the RS232 communication of the PIC24FJ1024GB610 microcontroller. Thanks in advance.
Many thanks, I have found the cause of the problem and pushed the fix to the updates system.
Simply run Help -> Check for updates and the updated CAL file should solve the issue for you.
