MIAC USB Slave Source code Error in FC 8
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team,
The Miac Flowcode USB Slave Source Firmware Projects compiles fine in FC7 (Leigh fixed the issue about 1 month ago) however the same
Source project in FC8 has multiple errors including a CAN error
FC Compile
FC 8 Complie
The original MATRIX Project
MiacUSB Slave Flowcode V8.rar
(58.81 KiB) Downloaded 457 times
Re: MIAC USB Slave Source code Error in FC 8
Thanks Peter,
We are looking into this for you.
QMESAR
Post by QMESAR »
Hi Ben /Leigh.
Sorry about this however I was a bit busy when I tested this and did not realize what is going on.
This Miac USB I tested with Roy here http://www.flowcode.co.uk/mmforums/viewt ... 76&t=20121 then it did not work
you guys fixed it and it was fine,
Then thinking about it between then and now there were some pic updates not sure exactly what now trying to work in V8, I have this errors as shown,
could there be something in the updates that could cause this :) any case for now I just carry on with V7
:D :D
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Hi Peter,
Sorry, I meant to update you yesterday.
The issue is with the CAN component due to some major additions to the SPI component.
I'm currently still working through the CAN.
Will post again when I have it all resolved.
Leigh
QMESAR
Post by QMESAR »
Hi leigh,
No problem at all.
I was just confused as we tested the MIAC USB stuff in FC8 and then there were errors ,Ben did some stuff posted an update and then all was fine
then 2 weeks later I want to use FC8 and now I have an issue,I just lost it that I actually tested this in the intial release of FC8
Ok I will wait for you ,Thank a million for the update info.
Looks I am still ok in head :D
LeighM
Post by LeighM »
The CAN component is now fixed, will be rolled out on the update system very soon 8)
ps. needs updated SPI component too
I've pushed out the fix to the update system now, let us know how you get on.
QMESAR
Post by QMESAR »
Hi Ben / Leigh.
:D :D FC8 source code is running on my MIAC now!
Thank you very much ,It is appreciated :D
