glcd_ssd1963
jgu1
Has thanked: 1135 times
Been thanked: 299 times
glcd_ssd1963
Post by jgu1 »
Hi MM!
I think there are a bug in the component for the GLCD_SSD1963. If I add it to one of the dashboard and I try to zoom with mouse, it have a strange behavior. I get a lot of dots on the board.
apologize if I am doing something wrong.
Br Jorgen
Glcd_SSD1963.fcfx
(8.43 KiB) Downloaded 239 times
Re: glcd_ssd1963
Hi Jorgen,
There are two simulation modes for graphical LCDs available via the component properties. The point cloud simulation mode is made up of dots, if you change this to bitmap mode then it should draw as expected. There may be a problem using the bitmap simulation mode on larger displays e.g. it might run a lot slower.
jgu1
Re: glcd_ssd1963
Post by jgu1 »
Thank´s Ben, work´s…
Jorgen
