dsPIC33EP512MU810 PWM remapable pins
An area to discuss 16-bit PIC specific problems and examples
TaliG
Has thanked: 16 times
Been thanked: 14 times
Post by TaliG »
In the PWM remapable pins drop down menu,
Is it possible to add RE1, RE3 and RE6 please?
Re: dsPIC33EP512MU810 PWM remapable pins
RE1, RE3 and RE6 are all RPIxx type remappable pins, this means they can only be used for remapped inputs.
Remap pins marked RPxx can be both input and output.
TaliG
Post by TaliG »
Hi Benj
Thank you for your answare.
Only reason I asked, was because I made a small development pcb and used RE6 as a pwm output as it is listed as PWM4L in the datasheet so I thought I could use it as a pwm output.
I guess the only way to produse a pulse on this pin will be through the use of a timer interapt after all.
Lesson learned :) next time I ll have to do my homework :)
Thanks again Benj
George
